LesPaulGoth
03-06-2006, 11:10 PM
Well guys, I went to the track last Sunday...lets just say I was very dissappointed. I'll post my times and then I'll explain if you care to read on, but I would appreciate any insight as to why my car ran like this:
(all these times are in order through the day)
14.747 @ 93.1 mph 2.275 60' .163 r/t
15.531 @92.10 mph 2.595 60' .113 r/t
15.005 @93.26mph 2.271 60' .075 r/t
14.975 @ 93.73mph 2.590 60' .133r/t
15.232 @ 92.89mph 2.67 60' .149 r/t
15.475 @ 91.68mph 2.758 60' .055 r/t
This was racing into a sick 10-15mph headwind too
Car:
1990 IROCZ
350 w/ headerback exhaust
Accel Coil/Wires
8* advanced timing
BFG 255/60 in rear
300lbs less than previous owners
Mods done at track:
12* advanced after 2nd run
Belt that bypassed PS, AC, Alternator (Battery read a solid 12v entire time)
20psi in rear tires
40psi in fronts
Weight reduction
NOW, the previous owner ran it bone stock on stock tires and ran a 14.6 with a 2.2 60' time and trapped at 95mph.
MY EXPLANATION:
My first run was pretty smooth, did a nice little burnout and hooked up nicely at the launch..as I was going down the track I felt good and after I saw the slip, I thought "this is going to be a good day".
I thought the second run was a fluke, however I got zero traction off the line and I tried to launch exactly the same, preloading the same as well (est. 2500rpm, tach is broken)
After the third run, I found out some nice information: my friend in his turbo beetle behind me informed me that ONLY ONE of my tires was spinning on the burnout before the staging...I was roasting only the DRIVERS SIDE TIRE. This, would mean that I lost the posi aspect of the posi rear...
I realized a few weeks ago that I had a bad axle seal because I was getting oil stains on the inside of my drivers side wheel...denoting that I was losing gear oil...but I didn't think it was that bad, since on the street, I was getting nice traction with both tires. Would a loss of gear oil make my rear operate like an open diff? Which was essentially what happened at the track, after run one, I was all over the place off the line...could it be the burnouts that just killed my rear? I really tried to baby it off the line after the 2nd and 3rd runs to keep from slipping, because I realized what was happening, but that just didn't help much.
But still even with that information...how is run #3 so far off from the previous owners?
Car:
1990 IROCZ
Accel Coil/Wires
8* advanced timing
BFG 255/60 in rear
Mods done at track:
20psi in rear tires
40psi in fronts
Weight reduction
MY EXPLANATION:
