How much parasitic loss with M6.
wrd1972
03-06-2006, 07:43 AM
What is the magic % for the amount of parasitic loss on a 1995 M6 with 4.10 10 bolt rear-end.
I am guessing around 15%.
Is this right or am I off?
Injuneer
03-06-2006, 02:10 PM
Based on actual measurements on my car, first on the engine dyno (Superflow), then on the chassis dyno (Dynojet) in the same shop that built the engine:
NA: at 500 flywheel HP losses were 12.6%
1-stage N2O: at 635 flywheel HP, losses were 12.3%
2-stage N2O: at 765 flywheel HP, losses were 12.1%
The balance of the system was a steel flywheel Street Twin, totally stock T56, 3" chrome moly DS, Strange 12-bolt with 3.73's, 17x9.5" wheels with 275/40-17's.
I'd say to assume closer to 13% with "stockish" HP.
87DJP2001
03-06-2006, 02:26 PM
On a M6 with a STOCK setup the Loss on a dyno is between 16/18%. Note the Word Stock.;)
wrd1972
03-06-2006, 02:27 PM
Well we have anywhere from 13-18%
By stock do you mean stock M6 and 10 bolt rear end.
So when you are no longer stock, why does the number seem to change
87DJP2001
03-06-2006, 04:52 PM
Whatever it came from the factory with is stock.
buzz12586
03-06-2006, 09:17 PM
I thought loss would be greater through a 12-bolt???
Injuneer
03-07-2006, 08:14 AM
I would expect the losses to be greater with a heavy Street Twin, a heavy 3" chrome moly driveshaft (19#) and possibly a bit higher with the 12-bolt. Not sure why using the lighter weight stock components would increase drivetrain losses by up to 5%. Maybe someone could explain.
