Gauge Cluster doesnt work
Old Nov 3, 2002 | 11:05 PM
93 Zman's Avatar
I was putting my gauge cluster back in the SS tonight and everything was all in place and nothing. There are no lights, there are no readings at all. Only thing that works is the oil pressure gauge when I turn on the turn signal. Do you think the gauge cluster is screwed after the accident it was in. Does anybody know if this can be fixed. Thanks again
Old Nov 4, 2002 | 12:01 AM
Jerm93z28's Avatar
do you have all the other wires in the car hooked up? my project LS1 car doesnt have the engine harness/computer installed yet, and thats how my gauges are acting. they worked before i unhooked everything, so im pretty sure theats what it is causing the problem.
jeremy
Old Nov 4, 2002 | 01:00 AM
racehead's Avatar
I'd double check to make sure it's fully engaged the plug behind the cluster. Maybe the plug is loose and got pushed away from the cluster when you put it in ?
sdn1997rs
Dec 30, 2014 08:30 AM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
mr28
Nov 23, 2014 11:11 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
