Rear 3 channel ABS harness and sensor
Old Mar 5, 2006 | 12:16 PM
Z95m6's Avatar
I'm wanting an uncut 3 channel rear ABS harness. Its the harness that plugs up into the body by the fuel pump plug in and comes down to the rear end sensor. I'd also like a 3 channel sensor also. Let me know what you got.
Old Mar 5, 2006 | 08:09 PM
LIND's Avatar
Re: Rear 3 channel ABS harness and sensor
I have one off a 95 Z28 it plugs in buy fuel pump comes down to rear end and plugs in buy the disk brakes. is that what you need?
Old Mar 5, 2006 | 09:02 PM
Z95m6's Avatar
It sounds like yours is for a 4 channel rear end though. The harness i need should go down to the differential right in the center of the rear end. So i believe yours will not work for me unfortunately. Thanks for trying though.
Old Mar 5, 2006 | 09:06 PM
194bird's Avatar
i have the 3 channel that plugs in to the top of the housing but i do not have the sensor the ring gear took it but just make me a offer
Old Mar 5, 2006 | 09:11 PM
Z95m6's Avatar
$15 shipped?
Old Mar 5, 2006 | 09:13 PM
194bird's Avatar
give me or zip and i will check it tomarow when i get home from work and let you know
Old Mar 5, 2006 | 09:19 PM
Z95m6's Avatar
67114
Old Mar 11, 2006 | 09:51 PM
Z95m6's Avatar
Thanks to all that responded. A very nice board member by the name of Colin91z gave the harness and the sensor i needed. A very nice guy.
jj_burchiel
Mar 21, 2015 12:51 AM
Chet1185
Feb 4, 2015 09:51 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
