BigRed82
03-02-2006, 10:06 PM
1995 3.4 v6
I posted once here before and I eventually had to take it to the shop and left it there with them for 3 months. Got it back three days ago and it is STILL overheating when it's sitting still.
Quick overview of what was done at the shop: New Radiator installed, new radiator fan installed, Heater core has been boiled out (it was clogged so I wasn't getting any heat), new water pump, new thermostat, timing belt changed, EGR valve changed, new plugs + wires, radiator flush run through the whole system, and some other smaller things.
The hose that runs from the heater core to the water pump (the 5/8 on one end and 3/4 on the other + you can't buy this at advanced or autozone) burst at one point in time and I had to use a temp cut-fit connector to fix it. Only thing I can think is that it's restricting the flow of the coolant. It only overheats when it's sitting still & the fan kicks on at 210 like it's suppose to... when this happens the temp goes down somewhat and then goes back up to 3/4... which i guess is around 240. When this happens I turn on the heat to bring it back down. Another interesting note is that when it gets up that high (about 210) the air conditioning comes out hot... not warm @ all.
So what do you guys think I should do? Take it to a dealership and let them change that hose with the temporary connector, of course. But what else? It seems to me everything I could have possibly changed has been changed with the exception of a new heater core.
