17x9.5 front 18x10.5 rear questions.
5tircrazy
03-02-2006, 05:28 PM
Ok, so I am buying a set of rims, 17x9.5 +54mm offset in the front, 18x10.5 +58mm offset in the rear, and I was wondering what size tires would you recommend for them, especially the rears. And also, does anyone know if I am going to need spacers to get those rear wheels to fit? Any info would be great, thanks!
Injuneer
03-03-2006, 09:13 AM
The rear wheel has an 8.0" backspace. Its quite likely you will have a problem with the tire rubbing on the inner fender if you put a wide tire on it. A lot of hammering or a spacer might solve the problem.
Fronts you want a 275/40-17
Rears, choose from:
275/35-18
285/35-18
295/35-18
315/30-18
All those will generally fit on a 10.5" wide wheel. The 275 is going to look a bit "small" on a 10.5 though. 315's will definitely cause major rubbing problems with that 58mm offset.
5tircrazy
03-03-2006, 10:16 AM
Alright, thanks alot for the info. Ill look into getting spacers for the back and probably end up going with the 295s. I ordered a set of the Machined C6 Motorsport wheel replicas on ebay. Ill post pics of how they look once im done. Thanks again for the help.
