Gasket Ported Stock Heads or....
Old Mar 1, 2006 | 01:41 PM
Deenasty's Avatar
I have two sets of heads and dont know which to go with. ITs a comp 292 cam with all the bolt ons.
1. Stock Gasket ported heads with a 3 angle valve job, stock size valves.
2. 2.02 /1.60 camel hump heads. Valve job.
Which should I slap on?
Old Mar 1, 2006 | 02:15 PM
Dave89IROC's Avatar
Re: Gasket Ported Stock Heads or....
whats the casting numbers of the stock heads?
Old Mar 1, 2006 | 02:43 PM
angel71rs's Avatar
I'd go for option # 3... sell both sets of heads and put that money towards a good set of aftermarket heads.
Seriously, when that big cam (244* @ .050 ! ) starts coming into it's peak, the heads will be signing off. So you lose low end torque with the big cam, with no return to show for it upstairs. Either one of those heads is taxed with any cam past ~ 224* @ .050".
Old Mar 1, 2006 | 03:03 PM
Deenasty's Avatar
where is the casting number located? Is it the one that starts 333 bla blah blah? Would I be better off with a smaller cam?
Old Mar 1, 2006 | 06:21 PM
angel71rs's Avatar
http://chevy.jpbconcepts.com/3c10o1.html
If you are going to use factory heads, you're probably better off with a cam in the 218-224* duration @ .050 range. JMO
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Killer94z
Jan 13, 2015 12:06 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
