Should I reduce before or after the x pipe
Old Feb 28, 2006 | 03:47 PM
cabell84's Avatar
I am going to put together true duals (over the axle) this summer and plan to run 2 1/2 out the back. Would it be better to go down to 2 1/2 inch right after the collectors (before the x-pipe) or right after the x-pipe, or will this make any difference at all? Sorry if this is a stupid question, just didn't know if there was any difference in performance, sound, etc.
Old Feb 28, 2006 | 05:13 PM
Kataklysm's Avatar
Re: Should I reduce before or after the x pipe
It will hurt performance to downsize the piping. I don't think it will matter where you do it though, either way it will be a restriction.
Old Feb 28, 2006 | 06:47 PM
Greed4Speed's Avatar
After. There has been a couple local cars that did a 3" X dumped and then did 2.5" under axel pipes. No performance loss either. No matter what it'll still flow better than any 3" catback.
Old Feb 28, 2006 | 06:48 PM
teke184's Avatar
on a bolt on car...dual 2.5" exhaust won't be a real restriction...
relative to dual 3" i could be...but you won't lose hp from it i don't think.
i would save the money and weight and ground clearance by going 2.5" right off the collectors
Nayr
Mar 3, 2023 08:34 PM
IndyZman
Oct 22, 2015 02:17 PM
n2oblkz
Oct 12, 2015 01:53 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
