Clutch problems
Old Feb 27, 2006 | 11:45 PM
IdahoLT1's Avatar
Question Clutch problems
I had my spec stage 2 and specs steel flywheel installed about 1200 miles ago and i recently had the cat removed and no off road pipe. I never noticed it until 100 miles ago but the clutch pedal vibrates real fast like a foot massager when driving but i cant feel anything when shifting . Its consistant with engine rpm's so im not sure if its just from the motor or from the tranny. should i be worried
Old Feb 28, 2006 | 12:15 AM
87lt1rx7's Avatar
Re: Clutch problems
I just installed my ram hdx clutch and noticed the same thing. I don't know about your TOB, but the outside casing of mine was not completely round. at one point it had a ridge. my theory is that this is the vibration. this is honestly just a guess though!!
Old Feb 28, 2006 | 02:49 PM
IllusionalTA's Avatar
Re: Clutch problems
your just feeling harmonic's through the pedal.. It's not uncommon.. could possibly mean your t/o is going as well.. keep a ear out for erratic noise's.. when you push the pedal slightly does it go away?
Edit: I see you don't feel it.. So i'd not worry about it till a issue arose otherwise..
Old Feb 28, 2006 | 10:41 PM
IdahoLT1's Avatar
Re: Clutch problems
Dont the clutch kit come with new throw out bearings? I dont know anymore, there are so many rattles that i dont know if its something to be concerned about or just my dash vibrating loose.
Edit: what is the t/o that you were talking about.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
