Need Help, Header Question?
Old Feb 27, 2006 | 06:14 PM
02BlackSS's Avatar
I did a search and could not find a answer to this question: I have an 02 SS
M6 and want to put some Pacesetter LT's on it but, I do not know which ones to order. I quess you can get them with or without Emissions fittings. I am not sure which ones to get. Can anyone help me out and tell me which ones need to go on my car.. Thanks....
Old Feb 27, 2006 | 06:26 PM
slayer6x6's Avatar
Re: Need Help, Header Question?
Well if you want to do away with your air pump system, you should get the offroad or non emission headers. If you would like you keep your air pump, then you would want the headers with the air pump fittings. You car does not come with an EGR valve so you dont have to worry about that. If your state or county requires a visual test for your emission inspection then you might want to get the headers with the air pump fittings. If your going to get the offroad headers, its a good time to remove the entire air pump system so you can gain some underhood room.
Old Feb 27, 2006 | 06:35 PM
teke184's Avatar
its pretty straight forward...
do you want to keep emissions
or do you want to get ride of the emissions?
you will throw a code if you remove it, but it will have no affect on the running condition of the car. you'll have to have it tuned out eventually.
Old Feb 27, 2006 | 06:56 PM
02BlackSS's Avatar
Sounds Good, Thanks
Old Feb 28, 2006 | 07:01 AM
teke184's Avatar
whoa...deja vu
Old Mar 1, 2006 | 01:39 AM
LarrieuY2KSS's Avatar
wow that it is!!!!!!!!!!!!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
