fesgali
02-21-2006, 11:34 AM
Gotta be drained? Some guy at work said you can use "dry gas" (isopropyl alcohol) and it'll evaperate.
This is about a full tank of gas.
Getting water out of gas tank...fesgali 02-21-2006, 11:34 AM Gotta be drained? Some guy at work said you can use "dry gas" (isopropyl alcohol) and it'll evaperate. This is about a full tank of gas. teke184 02-21-2006, 11:47 AM you mean a full tank of gas or a full tank of water? how much water we talking about. just a little you can use the additive. should work fine fesgali 02-21-2006, 12:36 PM its a full tank of gas in the car thats been sitting in a garage for a year, i'm not even sure if there is water in it. Starts to run crappy when it gets to 180* (temp). Just wanna cover all my bases. LT1LE 02-21-2006, 05:19 PM The best thing you can do is drain the tank.... but your not going to do that so.... fill the tank up with 93 and drive it to about 3/4 of a tank and fill it up and drive it some more. you need to work all the old gas out of the system.... next time use a Fuel Stabilizer(STA-BIL) | ||
