Will 20" 10.5 rims fit on a 95 camaro?
KILMERKARZ
02-20-2006, 08:42 PM
I have found an awsome set of C6 rims that are 20" by 10.5 +56mm offset with 7.94" backspacing. I'm not sure if they will fit or not, please help. Also I dont mind doing modifications to make them fit if I have to. Thanx Guys
:bow:
KILMERKARZ
02-20-2006, 10:27 PM
Sorry I forgot to specify, these will be for the rear only, the front will have 18s
Injuneer
02-21-2006, 01:22 AM
Width-wise, you will have the same problems as people trying to fit a 17x11" 7.93" backspace ZR1/GS offset wheel. Read the FAQ about that size wheel. It shows what you might have to do, regarding cutting the jounce bumper bracket, hammering the inner fenders, recentering the body over the rear axle, rolling the fender lip, etc. The fender lip should not be an issue, since the outside edge of the tire, on the 10.5" wheels with that backspace will sit about 1/2" deeper in the wheel well than the 11" wide wheel with the same offset.
KILMERKARZ
02-21-2006, 11:02 AM
Awsome, might take a little elbo grease but I'm sure it will be well worth it.
Thanx for all the help!!! :D
