keyless entry question
LqMth
02-20-2006, 03:39 PM
The keyless entry on my '93 (ugly square 2-button transmitter) hasn't worked since I got it. The d/s and p/s switches inside don't work either. The switches have a common power and ground. The fuse is good. Would the keyless entry not working cause the switches to not work also? I noticed in the wiring diagram that the keyless entry reciever is in-between the switches and lock actuators. Can anyone tell me where the ground would be or what the chances of the reciever being bad are? Any help is great because my manual is about 5 states away. I got the basic diagram on shoebox's site. Thanks Nathan
LqMth
02-20-2006, 09:34 PM
TTT for the evening crew.
6SpdLT1Z
02-20-2006, 11:14 PM
Not real sure, have you tried grounding your keyless entry per how shbox's website describes? That may atleast fix your keyless entry. If not they're is probably something not working. Lock Acutaer (sp) or something.
LqMth
02-21-2006, 02:13 PM
I didnt see the part about grounding the keyless entry. I'll look that up. I doubt both of the actuators are bad. Nathan
