ABS Light
Old Nov 2, 2002 | 11:03 PM
Black01_Z's Avatar
ABS Light
For some reason my ABS light has come on. I took the car to Firestone and they checked out my entire brake system and said nothing was wrong with it. I was wondering if anyone knows something?
Old Nov 3, 2002 | 12:03 PM
racehead's Avatar
I'm no expert, but I'd disconnect the battery for a few minutes and re-connect it to see if that clears the code.
Old Nov 3, 2002 | 03:42 PM
Black01_Z's Avatar
tried that, any other suggestions?
Old Nov 3, 2002 | 04:05 PM
racehead's Avatar
That tells me that you have an active code. Somethings actually wrong. About all you can do is check each wheel sensor to make sure each plug is plugged in at the sensor and that the wires leading to this sensor within about 2 feet of the sensor aren't cut or rubbed through or anything. Other that this you need for someone to read the actual code to see where the problem is. Sorry I can't help you more than that
Old Nov 3, 2002 | 09:04 PM
Black01_Z's Avatar
Yes they checked the master cylinder and the sensors at each wheel. The entire system is fully functional. The brake goes down as far as i push it. I took it to another mechanic he told me he doesnt know why the light is on.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
