crAzy95z28
02-18-2006, 03:34 PM
I recently went to LS1 brakes and i did bleed the brakes from the rear to front starting with the rear passenger.
Now my ? is can i go ahead and bleed the ABS now? Cause i remember taking off one of the lines from the abs.
I do have a brake bleeder pump. Which i can connect a rubber hose and then pump the abs which sucks air out of the system till brake fluid comes out into a container.
Is this ok, or would i have to redo the entire brakes?
