95camaro3400
02-15-2006, 09:42 PM
does the engine have to be removed or lifted to change the steering rack if so or not what has to be removed to complete this project?
96 trans am steering rack95camaro3400 02-15-2006, 09:42 PM does the engine have to be removed or lifted to change the steering rack if so or not what has to be removed to complete this project? Stoopalini 02-15-2006, 11:25 PM I replaced mine not too long ago. The steering rack will come right out, nothing extra has to be removed. Thomas. Zcrazy5150 02-16-2006, 02:01 AM Just did this myself. The engine DOES NOT have to be removed OBE1 95Z28 02-16-2006, 05:57 PM Steering rack bolts to the front of the K member; no need to move engine. Disconnect power steering hoses, unbolt steering "coupler" from steering shaft, and disconnect outer tie rods from steering knuckles. MyShibbyZ28 02-16-2006, 06:56 PM What everyone else said. There's two big bolts in the K-member, the two power steering lines, and tie rod ends to remove, than slide it out. | ||
