93 A4 2.73 vs 97 GT Mustang
theroad64
02-14-2006, 08:11 PM
This Fri I have a run scheduled with a 97 GT..he has the PI swap done, if you don't know thats the 99+ heads/cams onto the 96-98 motor. Ends up with 10.5:1 CR and 35-50 HP gain. However, the kid cannot drive worth donkey nuts, and never got below a low 15 before head swap. He's untuned and running stock exhaust manifolds.
I have a CAI and a high flow cat/TB bypass, and fresh Potenzas.
Me or him?
mthegodfather
02-14-2006, 08:17 PM
It might be close with those gears you have.If he has some gears I might give the win to him.
91RSLT1
02-14-2006, 08:55 PM
I say the edge goes to you. The gears (2.73) hurt a bit but he is untuned, however if he can drive it should really fun/close.
Mike 92LX
02-15-2006, 09:29 PM
If he can't drive he is toast. Good luck!
theroad64
02-22-2006, 07:32 PM
He declined to race after I ran a 13.90 with listed mods.
IdahoLT1
02-22-2006, 09:46 PM
thats a pretty good E.T. What was your trap?
Bersaglieri
02-23-2006, 08:43 AM
Nice kill :bow: I love when they chicken out.
-Dustin-
theroad64
02-23-2006, 04:38 PM
99.15 :)
396D1SS
03-03-2006, 05:30 PM
you will win...period
HardcoreRM125
03-07-2006, 12:30 AM
Sure he did the swap?
Who would do all the work and still run stock manifolds?
Sounds fishy to me.
Them things sure are slower than all **** though when their stock:D And the lack of torque makes them a poor excuse of a pony car.
1BadAzzGT
03-08-2006, 07:19 PM
Sounds fishy to me.
Probably because I assume he's discussing the 96-98 SOHC engine and when you upgrade to 99+ heads it gets you some horsepower? I dunno ;)
HardcoreRM125
03-08-2006, 08:39 PM
Yea thats what I mean though. It gets you some power, but it gets you alot more to throw headers on it. And if you already have the heads off, how long does it take to throw headers in. Mustang parts can be found relatively cheap too.
1BadAzzGT
03-08-2006, 10:01 PM
Negative. Heads is a bit more power then the headers all day.
But you're right, if you already have the heads off, it makes a lot more sense to go ahead and put headers on. But.... have you ever changed headers on a 4.6? If you think an LS1 or LT1 is a PITA... try the 4.6 ... took me 12 hours to do my headers with stock K member. Not an easy task and VERY time consuming.
The poster is right as well. Putting PI heads on a 96/98 block = approx 10.5:1 CR.
HardcoreRM125
03-09-2006, 01:12 AM
No, I didnt mean you would get more power from the headers than the heads.
I meant, that you will make alot more power throwing headers on it, especially if you already are swapping the heads. And if the heads are already coming off, you already have the manifolds off. If the manifolds are off, you have to be a ****ing idiot not to put headers on then. And its not like you have an excuse like its to hard to do if you already have the heads off.
Things just dont add up.
