boost control on super charger
jmh96z28
02-12-2006, 09:45 PM
is it possible 2 turn the boost up and down on a super charger lik a turbo.so u dnt have 2 put all that stress on the motor when its not being used.
markinkc69z
02-12-2006, 10:01 PM
No, not at this time. There is no stress when not under boost.
jmh96z28
02-12-2006, 10:04 PM
ive always ben a turbo guys so does a super charger always push 12 ps1(if thats wat ur running) even when not needed or does it kit in or wat.sounds dumb but i need 2 no lol
markinkc69z
02-12-2006, 10:10 PM
What happened to your spelling? A centrifugal's airflow delivery is tied to the rpm the compressor is running. When the engine is not under heavy load a bypass valve is open that vents the supercharger's airflow delivery. When manifold vacuum drops the bypass valve closes and then the engine is breathing through the supercharger. As rpm increases the supercharger delivers more air than the engine can normally inhale creating "boost" and pressurizing the intake system above atmospheric.
jmh96z28
02-12-2006, 10:13 PM
well well.thank you doctor sc.lol.really tho
ss#1230
02-13-2006, 02:55 AM
ive always ben a turbo guys so does a super charger always push 12 ps1(if thats wat ur running) even when not needed or does it kit in or wat.sounds dumb but i need 2 no lolwell well.thank you doctor sc.lol.really tho
:confused:
