luckyou03
02-12-2006, 06:19 PM
Can someone tell me the length from center of bolt to center of bolt of the stock lower control arms? Also I have relocation brackets and I was going to use the lowest hole. Do I still use the stock lca length or make it longer, shorter? thanks
Greed4Speed
02-12-2006, 07:16 PM
Should be the same length if they were properly installed. The only time you need adj. LCA's are when you need to move the wheels in the wheelwell.
luckyou03
02-13-2006, 12:32 AM
already threw mine out, and I have nothing to go by.
94badrag
02-13-2006, 04:35 PM
go to this thread on page 3 in this section and check out the link. it tells the measurement you ask for.
LCA Install Write Up???
luckyou03
02-13-2006, 07:50 PM
cool I found it, 19 1/4 for future reference.
