What kind of Bass Blockers would be good to use on my factory monsoon mids?
Old Feb 12, 2006 | 05:14 PM
KillerTA's Avatar
I don't know much about bass blockers but my mids distort from low bass when the volume is up and it sounds like crap.
Old Feb 12, 2006 | 05:55 PM
LS1 RULZ's Avatar
Re: What kind of Bass Blockers would be good to use on my factory monsoon mids?
If you want a simple first order filter (6dB/octave) all you need is the following formula.
C = 1 / 2 x Pi x f x R
C = capacitance in micro farads (uf)
Pi = 3.1416
f = cutoff frequency in Hertz
R = impedance of the speaker (For a Monsoon mid-woofer this would be 2ohms or 4ohms for a typical after-market speaker)
So for a cutoff of 100Hz you would plug in the following figures for a Monsoon mid-woofer...
C = 1 / 2 x Pi x 100 x 2
C = 796uf or 800uf
You would then connect the capacitor in series with the speaker in the + wire.
If you want a steeper rolloff you would need a 2nd order filter (12dB/octave) which adds an inductor to the filter.
For a 2nd order Linkwitz-Riley high pass filter you would use the following formulas...
C = .0796 / R x f
and
L = .3183 x R / f
C = Capacitance in micro farads
L = Inductor in milli-henries
R = Impedance of the speaker
f = the desired cutoff frequency
So for a 100Hz cutoff using a 2ohm Monsoon mid-woofer...
C = .1796 / 2 x 100
L = .3183 x 2 / 100
C = 898 uf
L = 6.37 mh
Old Feb 12, 2006 | 06:00 PM
LS1 RULZ's Avatar
I forgot to mention that for a capacitance that large you would probably need to use several smaller values in parallel with each other.
Old Feb 14, 2006 | 10:21 PM
Fuji_LT1's Avatar
or just try a few sets from a local best buy and call it a day, rather than trying to figure out what the heck mr wizzard is trying to say.
look man i don't mean to make fun but its a FACTORY sound system, not a 10k billy bad a-- set up.
prob a 100 or 150 hertz should fix your issue though, a sub would be a good idea to back fill the missing bass range. and yes you can ad a sub to a factory system with out going crazy.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
ChrisFrez
Aug 12, 2002 11:50 AM
Red97LT1
Aug 4, 2002 08:01 PM
u8dusst
Jul 25, 2002 09:07 PM
