turbo or super charger
jmh96z28
02-12-2006, 05:46 PM
thinking of geting sts but my car is dropped 3 inches alround.so clearance is a issue.does anyone have any solutions on how i can fix the clearance issue with out rasing my car.also that system is like 4000.is there a good super charger kit that comes with everything for about the same price.and wat do you think will make more power.also when it comes to preping your engine 4 a turbo or super charger;is it the sam for a turbo as a super charger.
Kevin_315
02-12-2006, 07:19 PM
I dont know how much procharger is but i favor them.
and such as far as prepin the engine, i cant say from experience but from what ive read i dont know why it would be different, still forced induction. Just depends how much boost your planning to run on either
cbrakllr88
02-12-2006, 11:14 PM
prochargers are about 5-6 grand depending on the kit you get. you can get the d-1sc which produces more boost but you need injectors and a fuel pump. the p-1sc comes with everything you need but if you plan on forging your motor later and running more boos t i would go with a d-1sc kit. if you want a turbo i would look at gmrspeed.com at the single turbo kit. its $4,000 i beleive. good luck on your purchase.
jmh96z28
02-12-2006, 11:15 PM
but gmrspeed.com dnt have kits 4 lt1s
cbrakllr88
02-13-2006, 11:40 AM
oh ok thats the thing im running an LS1. I was going to go with a procharger D-1sc but my buddy talked me into goin g with a turbo. You can more more power at less boost and make the power sooner in the RPM range. I dont know about turbos for an LT1. Try STS or JLturbo.com. but they both are rear mounted turbos. I favor front mounted. Although they are pushing pretty good numbers with rear mounts. good luck.
cbrakllr88
02-13-2006, 11:49 AM
I found a place that sells front mounted turbo kits for an LT1.Go to proturbokits.com then go to GM street kits. I believe they sell a kit for $4,000 for your LT1. hope this helps.
96TurboTA
02-13-2006, 01:06 PM
Forcedinductions.com is the reseller for proturbokits.
Geoff Chadwick
02-13-2006, 02:43 PM
If you're really worried about ground clearance, you could also look into ovalized pipe. Dr Gas is one source I've seen people use http://www.drgas.com/store/home.php?cat=8
jmh96z28
02-13-2006, 08:58 PM
right on you guys help a bunch.thx
