streetbad
02-11-2006, 04:52 PM
Thank You
Will a D1 crank pulley work with a F1 head??streetbad 02-11-2006, 04:52 PM Thank You markinkc69z 02-11-2006, 05:46 PM Do you mean D1SC? if so then yes. streetbad 02-12-2006, 10:45 AM Do you mean D1SC? if so then yes. No, The pulley I have is for a oil line type D1. What is the difference in crank pullies between a D1 and a D1SC? streetbad 04-09-2006, 10:25 AM No, The pulley I have is for a oil line type D1. What is the difference in crank pullies between a D1 and a D1SC? Is there a diference in offset? Would a spacer change line this up? Do I need to get a pulley for a D1SC? KS91Z28 04-10-2006, 11:18 AM There is no difference in offset, just diameter. You just need to calculate your max impeller rpm to make sure you don't overspin the blower. streetbad 04-10-2006, 06:20 PM Thank You KS91Z28!!! The Crank pulley I have is 7.65 dia. What is the diameter of the crank pulley for a D1SC? KS91Z28 04-11-2006, 02:34 PM For most kits, it's 7.65, but ATI also has a 8.5" crank pulley available. 95 Z/28 LT1 04-11-2006, 03:38 PM I have one of those and it's huge. It comes pretty close to the swaybar. For most kits, it's 7.65, but ATI also has a 8.5" crank pulley available. | ||
