SMUJeremy
02-08-2006, 04:46 PM
I am about to buy some brakes from a member on the site, I just wanted to make sure I got everything.
He is selling me 2 Calipers, 2 Rotors, 2 Spindles.
Do I need the ABS Wheel Speed Sensors Hubs or can I reuse my LT1?
I will be ordering Earl SS Brake Lines.
Anything else I need?
2000GTP
02-08-2006, 05:54 PM
The hubs are interchangeable from the LT1s to the LS1s. Sounds like you got everything covered. If your ball joints are worn out, it may also be a good time to replace those as well since you will have all of that stuff apart.
SMUJeremy
02-08-2006, 06:03 PM
Oh yeah, I was going to get the PST front end rebuild kit.
http://www.powerperformancemotorsports.com/ProductDetail.asp?ProductID=79
And rent a ball joint press from autozone. I have to do my rears also, so I was going to buy some autozone rotors.
What is a good pad that doesn't squeek or dust?
Also any other washers/nuts/etc I need?
Z95m6
02-08-2006, 06:24 PM
you also need the bracket that mounts the caliper to the spindel.
SMUJeremy
02-08-2006, 06:36 PM
Yeah, I believe he said those would be included.
Anything else?
