Electric Fan(s) recommendation
97RedT/AWS-6
02-08-2006, 02:22 PM
I have a Vortech S-Trim with the 6.66" crank pulley and a Be-Cool 2-core radiator and am having issues with cooling while stopped. Due to the lack of clearance, I can't seem to find any electric fan(s) that will fit and provide adequate cooling. I have about 4" of clearance, so the stock fans don't fit, and the 16" flex-a-lite trimline I have in there doesn't cut it.
Any suggestions, or can anyone point me in the right direction?
joe-96z1le
02-08-2006, 07:12 PM
I'm using a Spal dual 11" setup with some custom mounting brackets on a stock radiator. This setup pulls about 2700-2800 cfm. Works very well.
Spal also now makes a single 16" fan, 3.75 inches thick, 3000 cfm. Using a single 16" fan will allow you to position it for maximum clearance.
markinkc69z
02-08-2006, 08:25 PM
Its Spal or nothing as far as I'm concerned. The 16" on my 69 sounds like a F16 but it really gets the job done.
97RedT/AWS-6
02-09-2006, 01:40 PM
Thanks. Never thought of Spal, but looks like I'm gonna order me one. :)
God, it'd be nice to run the air conditioning again.....
will62085
02-09-2006, 02:22 PM
AC? its february!
look into some pushers? that or pull the radiator in some and run the stock fans
97RedT/AWS-6
02-09-2006, 02:24 PM
Ha, looking ahead to the summer in Phoenix. I've already cut the radiator core support and pulled the radiator in some, stock fans still won't fit.
97WS6SCharged
02-09-2006, 03:30 PM
You might look at the flexlite 210s. Alot of people run them on S10s where space is also at a premium. :)
