February Nitrous Specials!!!
Old Feb 8, 2006 | 11:40 AM
Nitro Dave's Avatar
February Nitrous Specials!!! EXTENDED
We know that its hard to stretch your income tax refund as far as your wants and wishes. So here at Nitro Daves we have put together many different packages to help it stretch alittle further.
These specials are good until the first March.
You will need to call your order in at 1-866-648-7637
Group 1
Our Custom Dry GTO Halo system..
GTO Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
NX automatic bottle heater,purge,fuel pressure safety switch,nitrous pressure gauge,NHRA valve and blow down tube.
Our Trick digital window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
NGK TR6 Spark plugs...
Special price 859.00
Group 2
Our Custom Dry LS1 F-body Halo system
F-Body Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
Group 3
Our Single Nozzle LS1 based Dry System
Group 4
Our Dual nozzle LS1 Based Dry system
2 Dry nozzles,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings,hoses and hard ware.
Our Trick Digital Window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
Special price 825.00
Group 5
Nitrous Express single nozzle wet system
NX complete stage 1 EFI system
Special price 959.00
Group 6
Our Custom LS1 plate system...
Your choice of stock or 90mm.
billet plate,o-ring gasket,throttle extention bracket,jetting from 50-200,10lb bottle with 45 valve,stainless steel quick release bottle brackets,300 hp lifetime warrenty solenoids with purge port desighn,all mounting hard ware,hoses and fittings..etc
Special price 1,075
Group 7
Our Famous Dual nozzle special..
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.10lb Bottle With NXs 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value) :eek2:
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Group 8
Our Custom LT1 plate system...
Your choice of stock,52 or 58mm.
Special price 1,124.99
Group 9
Misc Discounts
1.BMN window switch with first gear lock out... 100.00 while suplies last.
2. All of our dedicated fuel systems have 40.00 off...
3.10 percent off our custom console switch panels and solenoid brackets.
Do to being to busy and not getting the March specials posted we have extended these specials until the end of March.
Thank you for all your support.
Dave
Old Feb 8, 2006 | 11:25 PM
JodyJ's Avatar
Re: February Nitrous Specials!!!
Nitro Dave,
I checked your website, but I don't see the LT1 plate system. What's the price for the plate system, if I already have the NX kit?
Do you guys, have them in stock?
Thanks,
Jody J.
Old Feb 9, 2006 | 09:35 AM
Nitro Dave's Avatar
Jody,
WE are building a new web site. All the new pictures are going on there. The plate conversion sells for 285.00.
Old Feb 9, 2006 | 09:40 AM
JodyJ's Avatar
Dave,
Thanks for the pics. Is this adjustable from 50 to 250 or 50 to 200? I though I remember it being 50 to 250 when you first came out with it.
Anyways, how do I place my order
Thanks,
Jody J.
Old Feb 9, 2006 | 10:01 AM
Nitro Dave's Avatar
Jody,
The system will easily flow that much. However the jets it comes with is 50-200.
You can call in your order at 1-866-648-7637
Dave
Old Feb 9, 2006 | 10:05 AM
JodyJ's Avatar
Great thanks Dave,
I'll give you guys a call sometime today
Jody J.
Old Feb 9, 2006 | 05:00 PM
2000GTP's Avatar
Forgive my ignorance as I am new to the nitrous scene, but I am interested in the group 7 package. When you refer to the "bellows", is that part of the intake elbow? How would I run the nozzles if I have a Trickflow elbow? Also, will the Gen X2 upgrade package work with this kit? Once again, thanks for the help, I know these are probably basic questions.
Old Feb 9, 2006 | 05:11 PM
FastLt1's Avatar
Are you going to do dual stage LT1?
Old Feb 9, 2006 | 06:28 PM
KGRESOCK's Avatar
Originally Posted by Nitro Dave
Jody,
Any installed pics?
Old Feb 9, 2006 | 10:18 PM
Nitro Dave's Avatar
The bellows is for the LS1 crowd. So in your case you would subtract the bellows (50.00) and the kit would be 549.99.
Dave
Old Feb 9, 2006 | 10:19 PM
Nitro Dave's Avatar
I do not have any installed pics at this time. You would think I would have been smart enough to take pics but it just sliped my mind.
Dave
Old Feb 10, 2006 | 06:03 AM
2000GTP's Avatar
Dave
Would you happen to have installed pics. of the group 7 kit or a kit similar to it on an LT1?
Old Feb 10, 2006 | 04:16 PM
streetrod93's Avatar
can you guys sell the tps window switch seperate, i'm in need
Old Feb 10, 2006 | 10:31 PM
Z-Attitude's Avatar
Dave I PM'd you for a wet system. Something like the grp 6 or 7 setup. get back soon. Thanks, Mark
Old Feb 13, 2006 | 11:22 PM
Nitro Dave's Avatar
Sorry I do not have a pic to share.
Dave
