T/A Racer
02-06-2006, 07:35 PM
okay so i was curious if the flywheel is neutrally balanced from the factory or if they balance it with the whole rotating assembly? thanks
flywheel balanceT/A Racer 02-06-2006, 07:35 PM okay so i was curious if the flywheel is neutrally balanced from the factory or if they balance it with the whole rotating assembly? thanks T/A Racer 02-06-2006, 07:42 PM okay nvm i just got done researching some more and found out i can reuse my stock flywheel without balancing, i just need to remove the couter weight. sweet. and the dampner is neutrally balanced. :D | ||
