Keyless entry programming
jonnybassman123
02-01-2006, 12:11 PM
What do I have to do to program a keyless entry remote to work with the existing security system? My car didn't come with the remote!
94BlackBowtie
02-02-2006, 09:03 AM
Are you talking about the stock keyless entry system?
6SpdLT1Z
02-02-2006, 01:59 PM
shbox.com
Basically, take a paper clip, unbend it... connect the two terminals... press the lock button, take out the paper clip. :p (thats if your car came with power locks and you buy the right remote for it off ebay)
Chevamaro
02-02-2006, 06:44 PM
Here's what the '96 owner's manual says:
-Turn the ignition switch from the RUN position to the off position. This will disarm the Vehicle and Content Theft-Deterrent/Alarm System.
-Remove the RADIO fuse. This fuse is located in the main fuse block, located on the left side of your instrument panel.
-Turn the ignition switch from the OFF to the RUN position three times quickly (within five seconds.) The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the hatch. Your transmitter is now ready to match your vehicle.
-Press and hold the LOCK and UNLOCK buttons on the transmitter for 15 seconds. The vehicle will respond as in step 3.
-When you have finished matching your transmitter, replace the RADIO fuse.
99blackSS
02-04-2006, 08:12 PM
-When you have finished matching your transmitter, replace the RADIO fuse.This is for 98+ too (I assume 97 also). Not sure what years the paperclip way applies to.
