attn. cali people need help with emissions
96m6lt1
01-31-2006, 04:58 PM
i may be moving to cali by next year and i would like to hear from the members with 96-97lt1 cars what ex.systems do you have,such as y-pipes cats etc...is it legal there to relocate the cats by using the random tech catted y-pipe etc. any help you can give will aid me with having my car compliant,thanks..btw i will be in the clovis/fresno area.
NovaTodd
01-31-2006, 08:58 PM
I have not had much of a problem with the smog checks. OBD2 cars have to have all readinesss tests complete. All emmissions systems have to be present and working. All cars have to run on the dyno and can't have an SES light on. Headers and CAI's must have a CARB EO number and you must have the EO decals that came from the manufacturer.
How strict these rules are will depend on the place you have do the smog check. Plus the prices will vary depending on location as all tests are done by independant stations.
Make sure you do the following items before the test:
Change engine oil
Change spark plugs
Drive the car on the freeway or highway for at least 1/2 hour to make sure everything is up to temperature.
96m6lt1
01-31-2006, 09:16 PM
thats not too bad i guess,my 96 is relatively stock,headers,cai,160*stat and a madz tune all i have to do is add the cats and reinstall the rear o2s
my 95 is a lil different,383 small cam that has passed cali.emiss. according to a few posts i have read,hi-flo cat to be installed,bbk headers,t76 hangin out back 14-20psi depending on my attitude;)the only problem i see is this car has a t400 instead of an OD.
i have a 90rs thats getting an lt1 and a rear mount turbo also
lastly an 88 s15,stock 350/700 guess i will be puttin cats on it too
NovaTodd
01-31-2006, 09:50 PM
The headers have to be CARB EO certified. That is the only problem I see with the 95.
The S15 will have to go to the referee station and they will check all the serial numbers for the year of the engine - LT1 into S15 (excellent !!!!!) is Ok carbed 350 will not fly.
The T400 should not be an issue as the test is run at 15 and 25mph. It is not checked that I am aware of.
96m6lt1
01-31-2006, 09:54 PM
thats cool i may sell the 90 but not too sure about that,hard to part with toys,but i want to get a tahoe for my sons mom.hey its only money!
truedualws6
01-31-2006, 10:57 PM
I have relocated magnaflow cats and passed smog about a mongh ago.
The tech never questioned my exhaust system, even though it's quite
different that the stock setup. Plus everything on my mods list except
the OBDI PCM.
Zack
02-01-2006, 12:04 AM
i have no cats, and an obdI pcm in my car...not smog friendly :o
