RedHottG2
01-30-2006, 03:13 AM
If I was to do a A4 to T-56 swap in a 96 Z28 would I need to use a 96 OBD11 M6 PCM or can you do some kind of programming to the A4 PCM to make it work ? If I need to swap PCM's would a 96 be the only one that will work or would a 97 also work ?
Injuneer
01-30-2006, 10:01 AM
Any of the mail-order tuners can program your present PCM for the M6.
kingslam
01-31-2006, 01:15 AM
dude you can send your PCM to member tjwong on here and he can program it for you cheap! I own a shop and he does my programming for several years now, he has a dyno too so his programs are all tested!
