Real HP in the LS1 Camaros?
teal98
01-28-2006, 10:05 PM
I'm sorry if this has been beaten to death, but I've not seen it. I know this isn't 5th gen related (except that the 5th gen will apparently have the real hp).
What was the real horsepower difference between the Corvette and Camaro in '98 to '02. From what I've seen, it was likely about 5-10, and the base SS really didn't improve that. So that would make my '98 a 335-340hp car and the '02 a 340-345hp car.
I need to know what to say when people ask me how much horsepower the car has :D Saying "310" for my black '02 seems inaccurate. Plus there's my case of curiousity (glad I'm not a cat!) :D
JasonD
01-28-2006, 10:20 PM
Heh...moved to a more appropriate forum. :D
DrewSG
01-28-2006, 11:00 PM
All LS1's output around 350-360HP, and around 370-380TQ.
greg_nate
01-28-2006, 11:02 PM
There are people on here who know every single detail of every model ever made, so they will chime in with the exact numbers.
However, having owned both an '02 SS and an '04 Vette coupe, I can tell you that the engines are *EXACTLY* the same with the exception of the throttle body, which is electrically operated, versus the cable operated TB on the Camaro. The engine was rated at 350 horsepower and 360 torque at the flywheel.
Here's some info that you may find interesting. My SS was a manual 6 speed, with nothing more than a KN intake and a Flowmaster muffler. My Vette coupe is an automatic 4speed. Stock, the Vette was no match for the Camaro 6spd. The LS1 6spds were bad a55.
teke184
01-29-2006, 12:08 AM
i say....stick with the 310 hp factory rating...and whoop their monkey ass when they think they'll own you.
:cool: much more fun
CLEAN
01-29-2006, 11:08 AM
the '01-'02 Fbody LS1's had LS6 intake manifolds, but a less aggressive cam than the previous 3 years of Fbody cars, or the Vette. My '01 Formula 6spd put down 330 lb/ft and 307 hp stock, so that puts it right at what they were actually quoting for Corvette numbers. I never got around to it, but people who put a hotter cam only in the later LS1 Fbodies get a substantial increase, even w/ no headwork.
I also had a 2000 C5, but it was A4, and it's hard to compare it to the '01. It had the performance axle, but being an automatic, it just didn't FEEL as quick as the Formula, even though it may have been. I never dyno'd it, but I can't imagine it would have put down any more than the Formula did to the wheels.
To answer your question, for all intents and purposes the engines had the same output, but GM fudged the numbers on paper to keep the pecking order in place, even though an Fbody would typically put down MORE power to the wheels than a similarly transmissioned Corvette.
CLEAN
01-29-2006, 11:10 AM
The fun part of that would be to find a buddy who's talking smack about his new 310hp Mustang GT, and go out and hand it to him, then have him figure out if your car REALLY has only 310 hp. ;)
1996z28m6
01-29-2006, 11:18 AM
LOL so what do you tell the ls1 owners that put down 280 rwhp stock and 300 rwhp with decent mods? Ive also noticed that most peoples vision of stock on this board is not exactly stock (i.e. different air filter, different lid, or just anything outside of touching the internals) :rolleyes:
theroad64
01-29-2006, 12:28 PM
Seems that the LS1 has a lot of variances in its last two years in the Fbody..my friend went thru two motors due to piston slap in his 2001 Z and then lemoned the car at 85k miles when the 3rd motor started to go.
97bowtie
01-29-2006, 10:09 PM
The same thing you tell the LS1 owners who put down 310 rwhp stock and the LT1 owners who put down 262 rwhp...the dyno isn't the end all of performance. :)
CLEAN
01-29-2006, 11:08 PM
LOL so what do you tell the ls1 owners that put down 280 rwhp stock and 300 rwhp with decent mods?:
I'd say congrats, they run w/ the low end of C5's I've seen w/ 290hp at the wheels.
teal98
01-30-2006, 04:00 AM
So even with the milder cam, the '01 and '02 F-bodies had the same output as the Corvette? That's interesting.
Did the '98 to '00 F-bodies also have a milder cam than the Covette?
Skull Leader
01-30-2006, 12:00 PM
I can keep up with a modded 2001 SS with my mods below. :D I have video to prove it.
JakeRobb
01-30-2006, 12:07 PM
At the M10 drag race event last October, I laid the smack down by 0.5 seconds on a stock C5 M6 (13.3 vs. his 13.8). I have a timeslip to prove it.
My uncle has a 2004 C5 M6 with a Corsa catback. We were playing on some backroads once -- I was right behind him at a stop sign. He got on it, and I followed. We ran up to 110 mph before he let off, and didn't gain any ground; I maintained 2-3 carlengths behind him the whole time. He's at least as good a driver as I am.
I don't know about you, but that's all I need to know about that. :D
toegead93
01-30-2006, 08:47 PM
From what I understand the 2001 & 2002 LS1 F-bodies had a different intake/cam combo which dyno'd much higher than the previous LS-1's.
Gun5
01-30-2006, 10:39 PM
so the camaro raped it? why didnt u keep it
JakeRobb
01-31-2006, 07:42 AM
'01 and '02 LS1 F-bodies use the intake manifold from the LS6. It flows better, and GM upped the horsepower ratings by 5hp for all four cars (Z28 and Trans Am went from 305hp to 310hp, SS and WS6 went from 320 to 325).
I've heard that the cam is actually a little milder in the '01 and '02 cars, but I don't know the specs.
As for "dyno'd much higher", I think 5hp was about all of the difference. The cool thing is that the LS6 intake manifold will support a lot more airflow to keep up with the mods you do later.
00cls1camaross
01-31-2006, 09:10 AM
yeah the 01-02 cam is milder
98-00 .500/.500 lift, 209/198 Duration, 119.5* LSA
01-02 .479/.467 lift, 207/196 Duration, 116* LSA
-Dakota
Capn Pete
01-31-2006, 02:36 PM
AFAIK, the F-bodies and 'Vettes shared the same camshafts in their LS1 engines, however if you look at the 'Vettes, they seemed to switch back and forth a couple of years:think:. The F-bodies on the other hand used the higher lift cam w/LS1 intake, THEN made the switch to lower lift cam w/LS6 intake, and they stayed that way.
FWIW, my '02 dyno'd 289 RWHP / 307 RWTQ, through an automatic with 4.10 gears, on a hot, humid day ;). Track #'s are in my sig. I think that's pretty typical for a "lightly modded" LS1 (lid & catback as the only power adders --- actually, the Flowmaster cat-back is a power ROBBER according to some people ;)).
In general, I refer to the LS1 as 350 HP, because even doing the math on 289 RWHP, that works out to be a 17.5% loss on 350 flywheel HP. M6's have less drivetrain loss, and therefore they typically dyno ~300 or more RWHP :cool:.
toegead93
01-31-2006, 07:13 PM
Those are probably typical timeslips, but I have seen a bone stock to the filter 2002 SS run consistant 12.9'sand heard of a few others. And yes the '01/02 cams were 'smaller' but the different LSA provided more overlap to take advantage of the of the better airflow provided by the intake. Every car is different; it may have only been 5hp that some see, but from what I have seen of the '02 cars thay seem to run stronger than other LS-1's at the track. I have heard (but not seen personally) of them dynoing as high as 310 RWHP.
