jamieSS
01-25-2006, 07:47 PM
My coolant level low light is on but my coolant is full. The light comes on about 5 minutes after i start driving but is off when i just start it up. Some one told me it may the sensor but... how do i check it?
Coolant level low??jamieSS 01-25-2006, 07:47 PM My coolant level low light is on but my coolant is full. The light comes on about 5 minutes after i start driving but is off when i just start it up. Some one told me it may the sensor but... how do i check it? moparman 01-25-2006, 10:12 PM That's a common problem. The sensor mounts on the radiator by the battery. You can take it out and clean it and see if that works, or do what a lot of people have done: disconnect it. wunfunLT1 01-26-2006, 09:32 PM My '93 Formula low coolant light has flickered now and then since I got it (40kmi ago). I changed the sensor ($34) and it does exactly the same thing. I think that air bubbles going past the sensor makes it act that way. Ignore (best solution) or disconnect. Good luck. buzz12586 01-29-2006, 06:50 PM How hard is it to disconnect and where exactly is it located?? moparman 01-29-2006, 07:39 PM Take the battery out, and you'll see it sticking out of the radiator. buzz12586 01-29-2006, 09:11 PM Sweet thanks. I'll have to give that a try next time I am under there. | ||
