Oil pan on a sixer
walt355
01-25-2006, 01:50 PM
Can you drop the oil pan without pulling the motor on a v6 Camaro. Im needing to swap oil pumps. Thanks
kallcium
01-25-2006, 02:46 PM
no you dont have to pull the motor but you do have to disconect it from the motor mounts and lift it or jack it up... It may require disconnecting some other things as well if they hold it from lifting adaqutly enough
walt355
01-25-2006, 03:48 PM
thanks, Im fixing to bid a job on putting a oil pump in a 94 and I was tring to get an idea of whats goin to have to take place. thanks again
