what gears are you running in m6
Old Jan 21, 2006 | 10:04 PM
194bird's Avatar
just wanting to know some times with a m6 and your rear gears to see what is the best gear for the m6 i am running a 9inch with 4.11 with stock car best time is 8.43 spinnin but was told i needed to go with a 3.70 gear
Old Jan 21, 2006 | 10:20 PM
94blackz14.2's Avatar
Re: what gears are you running in m6
Do you have anything to help with your spinning, like some sticky tires. If not I would start there. Try some DR's or slicks and watch those times melt away.
Old Jan 21, 2006 | 10:36 PM
194bird's Avatar
yeah was running 26/10.5/15 et streets also got boxed controll arms sphon floor mounted torque arm and adjustable pan hard can not fiqure out why i am spinin the hardest i could leave was 1500 the best 60 i got was a 1.8 any help would be nice
Old Jan 22, 2006 | 08:35 AM
magnumv8's Avatar
what air pressure in the et streets?
Old Jan 22, 2006 | 11:12 AM
194bird's Avatar
started out with 15 was not getting no wabble just spin so i put them at 13
Old Jan 22, 2006 | 01:31 PM
LBJ's Avatar
LBJ
4.30's stock 10bolt 7.93 1/8 N/A on 17" DR's on a 1.84 60'
Old Jan 24, 2006 | 04:44 PM
Mr 35th's Avatar
Thougth you had 4.10's
Old Jan 24, 2006 | 09:49 PM
TQdrivenws6's Avatar
Moser 9", 4.33s. MT ET Drag slicks. With everything in the suspension done other than having stock shocks, its best 60' to date is a 1.671 but now with QA1's and drag springs at all corners I am hoping to get into the 1.5x range. Note this is a 6 speed.
Old Jan 25, 2006 | 08:20 AM
limige's Avatar
pinion angle is a huge factor in hookup!
if your car has alot of power you can always stepup to a 28" tire as well. believe you me, they hook!
Alex Barnes
Jan 24, 2015 10:21 PM
ddr698
Jan 9, 2015 10:05 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
