Brake??
Old Jan 18, 2006 | 04:17 PM
black02z28's Avatar
Brake??
I was wondering what is the size of my stock rotors I want to upgrade my brakes can someone point me in the right direction I want the crossed drilled and slotted look thanks guys.
Old Jan 18, 2006 | 05:16 PM
respectirocz's Avatar
Re: Brake??
u have 12 in rotors up front with dual piston calipers
the easiest and cheapest upgrade
if not a new set of pads
is a c5 set up, which utilizes a similar caliper with a 13 inch rotor, a very common swap for ls1's
if u do a search for c5 brake upgrade you'll find more
and i'm just gonna point out
incase anyone wants to jump down your throat
u did say, u want the cross drilled and slotted for the look
Old Jan 19, 2006 | 08:58 AM
black02z28's Avatar
Re: Brake??
Where can I get a C5 setup I wanna do a complete brake job upgrade front and rear rotors,calipers,pads and also is it easy to do yourself?And also will my 16" stock wheels fit onto the c5 setup.
Old Jan 19, 2006 | 09:53 PM
Re: Brake??
its fairly easy from what i've read
theres a bracket that bolts with or behind the hub, i think u have to trim the stock spindle, the rest just bolts up
u need a 17 inch rim minimum for c5 brakes, 16 will not fit
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
