any scan tools
red 95 z28 lt1
01-17-2006, 02:03 PM
i was wondering if there are any cheap or inexpensive scan tools that will pull up codes on my car its obd1 but with the obd2 connector. the only one i know of is the snap on scanner that goes for over $2k. I also have a madz28 tune as well
Thanks Frank
jsetzer
01-17-2006, 02:18 PM
Do you have an interface cable?
red 95 z28 lt1
01-17-2006, 02:47 PM
no i do not
jsetzer
01-17-2006, 03:06 PM
IF you can convince autozone or someone that has an OBD1 scanner to let you do this, you can use some pieces of wire to connect the scanner to the correct pins on the OBDII connector. The only thing preventing one of their scanners from working is the shape of the new plug. Some people have actually chopped it off and put an obd1 plug on it.
Search on here for pinouts of the 1 and 2 connectors, then just use wires to jumper to the proper points.
Another idea would be to find an OBD1 connector from a 94, and splice it in under the dash so you have both style plugs....
red 95 z28 lt1
01-17-2006, 03:18 PM
sounds good but if i had an interface cable what would that do?
jsetzer
01-17-2006, 03:20 PM
You could plug it in to a pc or laptop and use something such as freescan (which is free) to monitor everything and pull codes. If you are thinking of buyint anything thats a good place to start, then you won't have to mail you pcm off to get the tune reflashed either.
AKM Cables (http://www.akmcables.com/)
moparman
01-17-2006, 03:24 PM
Check these refurb units. You'll also need the correct cable.
www.autocheckup.net/Refurb.htm
shoebox
01-17-2006, 04:06 PM
Thanks Frank
Autoxray and Actron are just of couple of readily available brands of scanners that will work on your car. Just make sure you get the correct cable for your 1995.
oneslowz28
01-18-2006, 01:26 PM
get a cable from moates.net i just got mine in today and this thing is verry well built. i have used it 2 times already and love it.
red 95 z28 lt1
01-19-2006, 04:13 PM
thanks for all the help:)
67fso
01-20-2006, 02:25 AM
Download TTS Datamaster for your 95:
http://www.ttspowersystems.com/DM_Software.htm
Buy a cable for your 95:
http://www.aldlcable.com/sc/details.asp?item=aldlobd2
$40 total cost and you're set.
