How many of you spray with the stock 10-bolt
gsdz28
01-16-2006, 09:06 PM
just wondering how many of you LT1 guys are spraying with the 10-bolt and are having it hold up?
Im planning on spraying a NX 100 shot here as soon as i get my kit hooked up, and i have 3:23 gears. On the street i run nitto 555's and looking to switch to the drag radial, and at the track i run 16 in. ET streets.
im also going to put a T/A girdle on it.
cpt_bimes
01-16-2006, 09:08 PM
i cut 1.5X's on my stock 10 bolt, no girdle. Spray off the line too.
mrr23
01-16-2006, 09:13 PM
well, they aren't lt1 cars, but both still have 10 bolt in them. i did put 3.73 gears in them. they did have 3.23 gears from the factory. run nitto DRs on both cars. wil lbe using the ET Streets this saturday. going to break a ten. 10 second ET or ten bolt. either will do.
Derrick Redd
01-16-2006, 10:12 PM
i cut 1.5X's on my stock 10 bolt, no girdle. Spray off the line too.Ditto. Except I do have the girdle. :)
OBE1 95Z28
01-16-2006, 10:33 PM
A4's are much easier on the rear than M6's; it's the shock that breaks the rears. You could always hit the spray after the launch if you're really worried.
AF96Z28
01-16-2006, 10:38 PM
I spray a 150 shot off the line. Everything was good until I started cutting 1.5X's 60 ft's. Then I cracked the carrier, and smoked and axleshaft. It's not if, but when with an M6
LameRandomName
01-17-2006, 06:28 AM
What kind of 10-bolts ARE they?
If they aren't the newer F-Body 7.625" rears, then they are either 8.2 or 8.5 corporates.
The 8.5" corporate is as strong as the old 12-bolt, if not stronger.
rskrause
01-17-2006, 07:56 AM
Check his sig.
Agree about the "when not if".
Rich
Mr_Bond
01-17-2006, 10:23 AM
Sprayed 150 off the line w/ stock 10-bolt stock w/3.42 gear (99 LS1 Zexel). Ran a 11.34@119 cutting 1.66. Ran the stock rear with both et streets and et street radials. Now I got a 12-bolt strange w/3.73 :D .
94irocz
01-17-2006, 03:53 PM
10 bolt out of a ls1 6speed, 3.42's from an ls1 6speed, with the slp posi. All put in my 94 z auto cuz I destroyed my 3.73's messing around on the street. Best its gone is 1.53 on a 150 shot. Its gone numerous 1.57's. Nitrous comes on at 2600rpms have a 2800 stall. This is all on mt et dr's. No girdle.
Fuels94TA
01-17-2006, 04:00 PM
Cut a 1.7 on the spary, it held for a while.
ltwonz
01-17-2006, 04:17 PM
I have sprayed a 150 shot on my stock ten bolt (with gridle) for 3 years nows, and the diff is just now starting to go.
nfa
01-17-2006, 04:51 PM
What are the signs of the diff going?
I've never sprayed my car yet, but will be doing so this spring through a m6 and stock 3.42 gears on et street dr's. Added a LPW girdle and pray that it lasts a little while :)
blkchevyz
01-17-2006, 05:01 PM
mine sounded like a train
good luck on that, i broke 2 sets of gear only pulling 1.8x and with only 380 rwhp
Cmr0z28
01-17-2006, 05:30 PM
I did a few times...then it blew up.
gsdz28
01-17-2006, 06:11 PM
yeah i have a A4, i guess we will see what happens, i'll just cross my fingers my 10-bolt stays alive a while, i don't go to the track that often so hopefully ill be ok.
nfa
01-17-2006, 07:07 PM
Yikes!
Mike Comp T/A #57
01-19-2006, 05:14 AM
I use stock 10 bolt. 1.47 60ft
T/A lt1
01-19-2006, 10:55 AM
I ran 10.23@133mph on the stock 10bolt with GM 3.42's in it before I decided it was time to upgrade. The car ran many low 10sec passes on it and I still have in in myshop unbroken. Later Clint
gsdz28
01-19-2006, 05:57 PM
cool, with the luck a lot of have been having im not as worried about it, i will stay a little concerned but not worried:D
nfa
01-19-2006, 06:42 PM
i bought a LPW support girdle (similar to the TA performance cover), but didnt get the stud kit that replaces the bolts on the bearing caps. Does anyone think its worth it to pick them up as well? its about $25.
buzz12586
01-20-2006, 02:48 PM
How are you M6 guys spraying off the line?? I launch with some clutch slip so after you are done slipping do you just nail it or what?
Titus
01-22-2006, 09:28 PM
i will spraying after i leave the line this year whenever i put my NX kit on, im sure ill blow it with 3.73's and a spec 3
AF96Z28
01-23-2006, 01:01 AM
Let it blow. I mean really, just set some cash back and have some fun. What's the worst that's gonna happen? :) I've blown 2 up and it happened off the line. My 9" should be here tomorrow!!!!!!!!
