CPOM
01-16-2006, 07:19 PM
I come to the serious thinkers with problems I ran into during my drivetrain buildup. My truck is powered by a Camaro 3800 v6 and I chose to use a Toyota r150F 5 speed transmission out of a 4Runner. Connecting the two is a bellhousing from a 99 Dodge Dakota 2.5L as it has the 60 degree pattern on the engine side and the Aisin transmisison pattern on the other.
My input shaft is a bit too short when mocked up, my 4Runner clutch disc is about .5" away from my camaro flywheel.
Now I have gathered many opinons about how to remedy this problem and I wanted to ask for opinions of others.
Clutch mechanism is pretty much all set as I am using an air cylinder modified for hydraulic use and all the dakota internals. A 4runner clutch disc fits neatly inside the camaro pressure plate. I have a rod of oil impregnated brass to get machined for a custom pilot bearing.
Option 1 is having a custom flywheel made based off the stock unit that is .5" thicker. This is a very safe solution but probably megabucks.
Option 2 is milling. Having a machine shop mill the bellhousing by .25" on both ends to bring the trans in closer to the engine. Some of my friends are weary of this option as it will reduce the bell flange thickness from .5" to .25" and the bell is cast aluminum. I understand it will probably be 2x the cost to have it milled on both sides versus one. I am also concerned at how "true" the finished piece will be. There is even an option about milling the front half of the transmission flange as I could then split my .5" over three surfaces. more money though...
Option 3 is sourcing the other Aisin-Seiki input shafts that will swap into this trans. The AX15 frmo a Jeep has a bit longer input, as dows the AR5 from an Isuzu. This option would make it necessary to source another clutch disc.
Option 4 is a flywheel spacer machined to .5" but I have been instructed I could affect the engine balance by adding more metal there. I am not concerned since I am using a junkyard flywheel anyway. The other concern with this option is starter engagement problems. Maybe another starter would be necessary.
Option 5 was another friend's idea was going to a shop that rebuilds clutch discs and have them build one with more hub offset to work in my application. I wouldn't have any clue where one such company existed, if they even do.
I am looking for a cheap and safe solution that doesn't have to be ready tomorrow. Anyone have an opinion on this or need pics of any particular area? You can read about my buildup in my sig line.
Chris
Chris
