94REDSTALLIONZ
10-31-2002, 01:53 AM
stock ls1 sway bar $15.00
stock ls1 hood (black) $50.00
stock lt1 torque converter $20.00
stock corner lenses (perfect shape!)$ 15.00
stock single cat lt1 y-pipe$15.00
OBD II Diagnostic scanner for 96 and up vehicle's $75.00:bow:
stock ls1 y-pipe$15.00
stock corvette L98 valve covers $10.00
metco driveshaft saftey loop (1993-2002) "red" $25.00
stock rear seat belts $15.00
lt1 wheel bearing (entire hub assembly) slightly used $20.00
stock ls1 air box 2000-2002 $20.00
rear t-top holders $20.00
stock ls1 exhaust manifolds 98's 99's and 2000 lol $15.00 a set
stock ls1 crank and alt. pullies$15.00
edelbrock pro intake (carb only) $10.00
Industrial electric impact gun!!! 1/2 inch drive $45.00:bow:
4L60-E trans pan drilled and tapped to use with temp guage $10.00
thanks guys,
carter
thanks guys,
carter
