cc89formula
01-12-2006, 03:42 PM
can someone explain sb2.2 heads to me? also what about 18* and 15* heads? what has to be changed to run any of these heads? good for a street motor? thanks in advance
headscc89formula 01-12-2006, 03:42 PM can someone explain sb2.2 heads to me? also what about 18* and 15* heads? what has to be changed to run any of these heads? good for a street motor? thanks in advance 96speed 01-12-2006, 04:31 PM http://i5.ebayimg.com/01/i/05/f4/31/b5_12.JPG Ryan sheppard00 01-12-2006, 05:06 PM there are several differances between the sb2.2's and even some of the 18 and 15 deg heads.. they can be good on the street but I would recomend a big ci small block.. on all three choices they will require special intakes, and headers. I'm not shure about acc bolt holes. there are a lot of people on here that know more abut those then me someone should post. Mindgame 01-12-2006, 06:58 PM http://nascarheads.com/chevy_heads.html Scroll down the page and there's a brief list of specifications for the 011, 021, 559 & 560 heads. Pay attention to what you're buying should you decide to buy used stuff. With the 18 & 15* heads you will need special pistons, shaft rockers, intake manifold and headers. The 2.2's will require all that along with a sb2.2 specific camshaft. Of course the studs and other hardware are different as well. -Mindgame SStrokerAce 01-12-2006, 08:59 PM can someone explain sb2.2 heads to me? also what about 18* and 15* heads? what has to be changed to run any of these heads? good for a street motor? thanks in advance If you want the more basic answer than what you have so far.... 18° and 15° heads have a valve angle that is that far off perpendicular (from the deck) tilted towards the intake or center of the motor. SB2.2 heads are 11° x 4° on the intake and 8° x 0° on the exhaust.... The x 4° on the intake means that it's also tilted away from the bore 4° so it's a canted valve head, just like a Ford Cleveland or Big Block. Bret cc89formula 01-12-2006, 10:22 PM oohhhh ok, well then these arent for me. i was looking for something a little more budget friendly and had head about these heads, just didnt know anything about them. thanks for the answers everyone. | ||
