Why can't I see my purge?
MetallicTrans96
01-11-2006, 02:33 PM
This may be a simple answer but my car has been sitting since November in my garage. I just installed a 90 degree brake fitting with 2 outlets from my purge solenoid.I then ran the lines out the front of my nostrils on my glasstech hood..lol..but anyways when i tried it out i could see the n20 in a white form...it blew all the way to the top of the celing out of both tubes...looked really sweet...then about 30 min later i brought the camera out to take a picture and when i pushed the button all that happend was the loud hissing sound...could not see any white n20....why is this...the garage is only heated from a space heater so it was probably 40-50 degree...kind cold...but can you tell me why this is :confused: ....thanks
1SlowFormula
01-11-2006, 03:17 PM
Sounds like your out of N2O.... Try warming up the bottle, but you may just have used it all playing with the purge. How long did you hold it?
MetallicTrans96
01-11-2006, 08:39 PM
Why would it still hiss so bad then if I was out...just pressure? My bottle was cold when i tried it the first time tho....i dont know...guess i'll wait till summer
andy katzelis
01-12-2006, 11:13 AM
1slowformula's right, you're out of dope. You'll be surprised how much "gaseous" nitrous is still in the bottle. The white you saw was the last of the "liquid" nitrous.
You can still use the pressure to test fittings and solenoids for leaks.
"White Knight"
01-12-2006, 11:42 AM
Get a re-fill and then give it a try
AutoRoc
01-12-2006, 11:00 PM
It's gone. Refill time.
MetallicTrans96
01-13-2006, 10:05 AM
Thanks...at least i got to see what it looked like:D
Mikes 1994 z28
01-14-2006, 10:51 PM
Your already out? Was the bottle full when you installed everything and purged it? If so, you may want to check your lines for a leak
SPEED750
01-15-2006, 03:30 PM
I agree, your out. I have a 10 pounder and I only get a few good uses before the liquid is gone, but the purge will hiss for days.:(
HeavyChevySS
01-15-2006, 05:14 PM
Also...make sure your bottle is sitting in it's brackets with the correct side down !!! :D :D
Post up some pics of the finished results...sounds cool !
MetallicTrans96
01-18-2006, 10:47 PM
Ya i have picture but i dont know how to post them....im pretty sure the bottle wasnt even close to full....how do i post picture on this thing...thanks
probably wont have the actually purge pic of it coming out until spring cuz i wont fill the bottle till then...unless i get impatient which will probably happen.
