Onebadlt1
01-10-2006, 12:41 PM
I have a 96 6 speed.. when i accelerate.. the shifter stands up.. any idea why? normal or no? thanks
Shifter stand up when acceleratingOnebadlt1 01-10-2006, 12:41 PM I have a 96 6 speed.. when i accelerate.. the shifter stands up.. any idea why? normal or no? thanks 96flame 01-10-2006, 12:52 PM If you're talking that it raises up towards the roof then your transmission mount is broken Colin91Z 01-10-2006, 01:15 PM If you're talking that it raises up towards the roof then your transmission mount is broken I agree. Replace it with a 1LE mount or an Energy Suspension mount. I have had the ES mount for 6 years with no problems at all.:cool: Onebadlt1 01-10-2006, 09:45 PM How do i replace the transmission mount? do i have to remove the tranny? instructions please Capn Pete 01-11-2006, 09:28 AM REAL simple! ;) Get the car up on stands or ramps, get a jack under the tranny to support it, unbolt the nut from the tranny mount (in the center of the cross member) then unbolt the cross member. Then remove the 2 bolts holding the mount to the tranny (or whatever is left of the mount ;)). Then bolt the NEW mount to the tranny, put the cross member back in place, and tighten everything up :). Should take ~20 minutes or less, start to finish :thumb:. | ||
