what amp are YOU using to push one 10" L5?
TruDualed95Z
01-07-2006, 06:13 PM
Ive been trying to decide which amp to go with to push one 10" L5 (2-ohm) in a stealthbox. The sub has a 450 watt RMS and handles a peak of 900 watts.
I was thinking of using an Alpine MRP-M350 mono amp, which has a 350 watt RMS x 1 at 2-ohms.
Any other ideas?
chuckd4more
01-07-2006, 09:53 PM
You don't want to underdrive the sub. Probly should get at least 450 to it or a little more
TruDualed95Z
01-07-2006, 10:23 PM
So any suggestions?
katie_06
01-09-2006, 08:49 PM
i dont have any suggestions because im in the same boat! Except i need suggestions on what to use to push one 12" L7. Anybody???
00cls1camaross
01-09-2006, 10:04 PM
im pretty sure that you arnt suppost to give the sub 100% of what it can handle... if i am not mistaken it is like 70 i think... so that amp will be sufficiant. i power a 10'' Type R 500 rms with that amp and it sounds great.
-Dakota
TruDualed95Z
01-14-2006, 12:46 PM
so id be good with the amp i named?
PentaVolvo
01-14-2006, 02:00 PM
Generally you are better off having a little extra power then not enough because with too little power you will tend to clip the amp by driving to overdrive it and hurt the sub
TruDualed95Z
01-16-2006, 10:47 AM
so can anyone suggest a better amp?
kick Z tail out
01-16-2006, 02:31 PM
95-100% of the RMS range is ideal. Otherwise you're going to strain the amp pushing the power.
Try to find something with 425-450 bridged RMS.
