Nx Wet kit and msd window switch question
always faster
01-05-2006, 12:28 PM
Ok im gonna buy a NX wet kit for my 95 lt1.Because i new to this world(n2o) i have a couple of easy question :
-Can my stock lt1 take 100shots without any problem?(engine as a perfect compression,doesnt burn oil at all)
-Is this windows switch will work on my car(i think so):
MSD-8969 digital msd window switch :special 89.95$ at summit racing
-What would be a good setting for the rpm(was thinking about 3000rpm to 5600rpm)
-Do i need something else except the nitrous kit(that come with all the hardawre,wot switch and everything) and the window switch?
Thank you all for your help :bow:
Nitro Dave
01-06-2006, 12:05 AM
The NX single nozzle kit is a nice system. The MSD wiondow switch will work juts fine. Your stock motor will take a 100 shot with no problems.You need to look into a bottle heater,pressure gauge,purge ,fuel pressure safety switch and NHRA fitting and blow down tube if you want a complete set up with all the accessories to help the system fuction to its full potential. NX makes a sytsem calles a GENX2 package.This will be a all in one system for all the accessories.
Dave
OBE1 95Z28
01-06-2006, 09:07 PM
The MSD window switch uses "pills" to set the rpm trigger points. This is a pain in the a** when you want to change settings as the pills come in a sets of 5 and are expensive. I got a Mallory window switch that has rotary wheels that lets you "dial in" your trigger points.
OBE1 95Z28
01-06-2006, 09:09 PM
By the way, it's the Mallory P/N 628 RPM Window Switch
Cmr0z28
01-08-2006, 04:32 AM
Don't get the MSD digital switch. A LOT of them turn out to be defective. Mine was.
