Help On Wiring a Predator Diablo Programmer
Old Jan 4, 2006 | 09:07 PM
camaross16's Avatar
Question Help On Wiring a Predator Diablo Programmer
I have diablo programmer that I’m using on a 1999 camaro ss. The 3 wires that connect to the circuit board on the black connector on the diablo programmer tour off. I need help because I don’t know which wire goes where. This circuit board with the 3 wires is found inside the black connector that plugs into the car. All I need is a small favor from any body that has a similar diablo programmer that plugs in a 99 and up ls1. The favor is if someone can just tell me where these wires go by opening the connector on their programmer. All you have to do is take four screws off, when open you wheel see a white, grey, and green wires that connected to a circuit board. The circuit board has little holes where the wires go into. Which wire goes in which hole? Thanks to any one that helps. (The holes should have color names right underneath each hole.)
Old Jan 5, 2006 | 12:07 PM
2001NBMZ28's Avatar
Re: Help On Wiring a Predator Diablo Programmer
I took mine apart but it has 8 wires and 9 pins on the connector - it's one of the first models that came out. Here's a couple phone numbers I got off RWTD's site that may help, they're in Mobile, AL: Tech 251.479.9452, Sales 251.479.9451 My buddy has one w/three pins but he won't be home until Saturday.
Old Jan 5, 2006 | 06:32 PM
camaross16's Avatar
Thumbs up Re: Help On Wiring a Predator Diablo Programmer
Thanks for helping out. I have also tried talking to diablo sports but they can not help me because they don’t want to be responsible if I don’t do it right. So they will rather not tell me where they go. That’s cool! Hopefully your friend has the same one I do, thanks.
Old Jan 8, 2006 | 04:39 PM
hazard2k's Avatar
I took mine apart for ya, I only have my camera phone with me so the pics are kinda crappy. You should be able to get what you need but if you need more info just ask... My predator is for my 99 Z28, so hopefully they are the same.. I would assume they would be.
The GREEN WIRE goes to the hole labeled "RED" (very bottom hole)
The GRAY WIRE goes to the hole labeled "BROWN" (Second hole up)
The WHITE WIRE goes to the hole labeled "BLUE" (4th hole up)
Hopefully thats all you need.. here are the pics: Good luck, Jeff.
Old Jan 8, 2006 | 10:06 PM
camaross16's Avatar
Thanks for all your help. I got my programmer back an running!
Old Jan 8, 2006 | 10:09 PM
hazard2k's Avatar
No problem, glad i could help. next time pull on the connector, not the wire! -Jeff
transam_388
Mar 15, 2015 11:53 AM
k1996z28
Jan 21, 2015 07:22 AM
Dec 1, 2014 08:08 AM
