suspension advice?
Old Jan 4, 2006 | 05:01 PM
slowpoke310's Avatar
suspension advice?
car is / mods are
95 z28 convertible -minor bolt ons (intake, plugs, hyp PP,edl headers, flow exh.) but 383 is in the build as we speak
-lowered eibach sportlines on 19's
-LCA's, Torque arm bar, PHR, tokiko springs
my front wheels are a little cambered even after alignment
am going to buy K-member and tubular upper / lower Aarms, should i spend the extra $ to get adjustable
im also going to change swaybars front and back -will i be OK with BMRs 32mm package? or does anyone suggest anything else?
also read some other threads and decided i will change subframe connectors, being that im reading its much better for verts. but also wanna know if it is really worth changing LC relocation brackets, especially that im 2" dropped???
Old Jan 4, 2006 | 11:47 PM
slomarao's Avatar
Re: suspension advice?
yes
Old Jan 5, 2006 | 04:31 AM
RE AND CHERYL's Avatar
The lower control arms are adjustable in stock form. You can get the after market ones with the adjustable hemi joints in them making each joint adjustable in two places. Whats the point???
If your dropped 2", you need relocation brackets. Good SFCs are also a must for verts.
Old Jan 5, 2006 | 07:13 AM
Honda Hunter's Avatar
Originally Posted by slowpoke310
car is / mods are
I have a 1994 convertable Z28 and Im going through the same thing. I just ordered LCA's, Relocation brackets, BMR sub frame connectors, and BMR adj PHB. Mabey this week Ill order the QA1 single adj all the way around with QA1 drag springs and either BMR rear spring or stock in back. Later on I way do the K-member and A-arms. First I want to see how the first set of stuff will work out, then so on and so fourth. Let me know any info and deals you find
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
jayblev95
Sep 26, 2015 09:44 PM
force10
Jul 30, 2015 04:56 PM
GT what?
Jul 14, 2015 10:17 PM
