Overheating problem...
Old Dec 29, 2005 | 11:49 AM
khojo16's Avatar
ok the other night wen i was driving my car overheated and discharged the antifreeze and everything else it does wen that happens bc the waterpump went ..so i just went and got another waterpump and thermostat and put them in last night and then i let the car run..filled it with coolant/water mix and then primed the system...but now wen it runs...the temperature gauge rises pretty quickly to 235 and i have a 180 deg. thermostat in there...and it repeatedly heats up wayyy too quickly and doesnt hold a temp. Can anyone help me figure out wut is wrong with this??? I was thinkin that maybe the cooling fans arent running and pulling the heat off of the radiator but maybe u guys know something i dont.
Old Dec 29, 2005 | 01:00 PM
TraceZ's Avatar
Re: Overheating problem...
Did you put the thermostat in backwards?
Old Dec 29, 2005 | 01:03 PM
khojo16's Avatar
no...everything is re-installed correctly...i just went out to the car recently though and let it run and the temperature went up to 235 and rising and i put my hand behind where the fans are and u cant hear them running and u cant feel any air being pushed around from them...so im guessing the temperature sending switch that plugs into the waterpump and attaches to the fans to turn them on is not working....$30 part..not a big deal and easy to fix...but i wanted to find out if anyone else knew something about this problem that i didnt..
Old Dec 29, 2005 | 01:04 PM
Kataklysm's Avatar
Bleed the air out of the system. There are 2 bleed screws on radiator hoses near the throttle body.
Old Dec 29, 2005 | 01:10 PM
khojo16's Avatar
already did that and i still have the problem... :/
Old Dec 29, 2005 | 01:15 PM
Fuels94TA's Avatar
check on the water pump itself and see that you connected the sensor back on which controls the temp on the pcm.
Old Dec 29, 2005 | 06:00 PM
Kataklysm's Avatar
Try bleeding it again, unless you got a leak somewhere there is probably just air in the system OR you got a bad thermostat which has been known to happen.
Old Dec 29, 2005 | 09:04 PM
khojo16's Avatar
well i know for a fact that the two thermostats i have (both 180 deg.) are in working order...did a lil test where u drop them in a boiling pot of water and if they open and then close wen run under cooler water they work....but the temp control is what is throwing me off...because everything is working fine except for the fans...they are not turning on at all even when the temp is well above 210...and as far as the sensor being connected...it is...i checked a lil bit ago...so now im still confused as to what the problem is...i think the sensor that is connected to the water pump that controls the fans is just bad....i mean it seems like that is the only other thing that could cause the car to gradually warm up and continue as it passes the 210 mark...because the fans just arent pulling the heat away from the radiator...sound right???
Old Dec 29, 2005 | 09:30 PM
94Z28WP's Avatar
Scroll down the page on shoebox's site and it tells you how to test the fans:
http://shbox.com/1/4th_gen_tech2.html#cooling
Old Dec 29, 2005 | 09:45 PM
khojo16's Avatar
thanks for the link...gives me alot of useful info that i did not know...
Old Dec 29, 2005 | 10:47 PM
khojo16's Avatar
i tried checkin the fans and replacing the fuses/relays...and the fans still do not kick on...any ideas on the problem???
Old Dec 30, 2005 | 12:41 AM
Lunch Box's Avatar
maybe your rad is bad?
I had overheating problems with my old half ton when the rad went
Just an idea since it seems like you have looked at everything else in the cooling system
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
