red 95 z28 lt1
12-29-2005, 10:59 AM
im looking for a rear sway bar for my car. i intend to drive it every day but i want it to be great for the drag strip. also i now have a moser 12 bolt with a ta cover, the sway bar rubs up against the cover, if i go bigger i am afraid it will create bigger problems with the rubbing. is there any kind of relocation kits? and is this possibly a cause of vibration at highway speeds. thanks for the help mods in sig
joe-96z1le
12-29-2005, 06:58 PM
I have a similar problem. My rear sway bar was close to the rear cover on the factory rear but with the Strange rear with TA cover, it rubs. Anyone have any suggestions?
ABA383
12-29-2005, 08:22 PM
Spohn sells a mount kit designed for aftermarket 12 bolts both for Moser and Strange. It spaces the sway bar a little lower on off the rear so it won't rub...I used that kit and the Spohn 1" solid Chrome moly rear bar when I installed my Strange. I have the LPW aluminum cover, too. Works, looks great...http://spohn.net/product.cfm?productid=1310 and http://spohn.net/product.cfm?productid=1333
--Alan
joe-96z1le
12-31-2005, 05:36 PM
Thanks for the info.:) This just confirms my thoughts on modding my car. Every mod always seems to require another mod you didn't realize would have to be done to make the first mod work (or work better).
convertz
01-01-2006, 08:31 PM
I would lust bake a spacer to go inbetween the mounts and the bar bushings. Go to a metal shop and get some 1/2 inch plate from there scrap pile and drill some holes in it.
but im cheap like that
-TG
