1FstFormulaV8
12-29-2005, 01:08 AM
So my friend and I were out about on a curvy country road. And I went around a curve and the passenger front tire rolled right off the bead. I was sighing and carrying on how I have to get the tire fixed and yada yada yada. While I was taking out the jack and spare. I find a can of starting fluid. I remember reading and seeing this little trick work, I gave it a shot. And I'll be damned if it didn't work like a charm. It put the tire right back on the bead no problem. I drove to the closest gas station and filled it with the correct amount of air. Drove home, no problem. Prolly about 7 miles home.
I know this is a VERY VERY dangerous thing to attempt. But it actually worked quite well!
johnnyb
12-29-2005, 10:15 AM
did your rim get messed up when it happened? ive reset the bead on a couple of tires- i just filled them up with air and they popped right on.
Injuneer
12-29-2005, 11:23 AM
For reference, what size tire are you running, on what size wheel?
1FstFormulaV8
12-30-2005, 04:22 AM
Stocker
235/35/16"
The lip of the wheel isn't a pretty sight.
johnnyb
12-30-2005, 11:19 AM
i thought that the stock wheels called for 245 or 255? if your tire is too narrow, it will be coming off again
4U 2 NV
12-30-2005, 12:19 PM
they have been using this method for years...in my opinion it can be sometimes less dangerous doing it this way because you can stand back and light the fluid from a distrance
Injuneer
12-30-2005, 01:11 PM
235/55-16 is a stock tire size. Base V8's came with 235/55-16 all-season tires. If you got the Z-rated tire option, you got 245/50-16's. A 255 was never standard. Most manufacturers recommend a wneel width of 6.5-8.5" for the 235/55-16.
Dave '97 Z28 M6
01-04-2006, 01:58 AM
Here's a vid of the lighter fluid trick:
http://videos.camaroz28.com/Player.aspx?fileid=9B3D15C7-4312-44A9-8237-EF8667DE6BD4&p=0
Resilient94LT1
01-04-2006, 09:40 PM
That's bad ass!
RICEFEDZ28
01-04-2006, 11:26 PM
Alot of off roading guys always carry a can of starting fluid it works wonders.
oneslowz28
01-06-2006, 11:46 PM
it safer alot of times even when mounting new tires. some of the larger 20" and above wheels are hard to seat the bead. i have put 100-150 psi in some and when the bead does set it sounds like a shotgun. this is also true for verry low profile tires too. if i have a tire that wont seat i always use the starting fluid/eather trick. it works great on those pesky lawn mower tires and atv tires too.
ive never had trouble with 20's and up
just takes a lil skill ;) :p:cool:
