nightrider93
12-28-2005, 07:54 PM
looking for the ideal compression ratio on a 355 or 383 to run about 150-200 shot. with heads, cam, long tubes, custom true duals, new rear end and tranny.
ideal com rationightrider93 12-28-2005, 07:54 PM looking for the ideal compression ratio on a 355 or 383 to run about 150-200 shot. with heads, cam, long tubes, custom true duals, new rear end and tranny. 396D1SS 01-02-2006, 04:50 PM 11:1 with 93 octane and a 150 shot will run fine but go with higer octane if you spray 150 plus n2oCamaro 01-03-2006, 06:33 PM The dynamic compression is more important than the static compression. The cam you choose will have a huge influence on the dynamic compression. http://cochise.uia.net/pkelley2/DynamicCR.html You can go here to learn more about it. | ||
