anyone fab a manuel rack in their 4th gen?
n20ta2
12-27-2005, 11:24 PM
I looked at the kit from madman racing but at 650 bucks plus shipping it seems pricey.I can get a rack minus the mounts and ends for 200 bucks from my local speed shop but would like to see if anyone else had tried this yet?Im a competent fabricator but im not sure on the bump steer and rod ends, thanks.
amean94ta
12-27-2005, 11:43 PM
same here subscribing
383Z4ME
12-28-2005, 08:51 AM
You might look at paracing.com they have lots of different pieces for a 4th gen including a bump steer kit for manual racks.
RBE17
12-29-2005, 12:33 PM
Although it is expensive, the Madman rack is very nice. A friend bought one and it seemed to be worth the money. There was a thread about this over at ls1tech.com a few months back.
Later,
Steve.
96speed
12-29-2005, 01:02 PM
Bumpsteer, rod ends, steering linkage, and some welding.
If you're a competent fabricator you can probably save a couple hundred bucks and weld yourself. However, the parts aren't that cheap. Good joints for the steering linkage are ~100 bucks!
AJE, PA & Smith Performance are other places I'd look. You'd probably get better responses in the Drag racing section of this forum. LS1tech has a very good section, too.
n20ta2
12-29-2005, 06:03 PM
thanks guys I appreciate the responces!!I will look into the ends and see if its worth my time to do it myself thanks.
CSJTA
12-29-2005, 08:50 PM
You should be able to handle it, I installed one in my brothers car which has a highly modified factory crossmenber, but wasn't that bad to do.
96speed
12-29-2005, 10:19 PM
FYI: The Smith Performance rack has a small tab welded to it for the driver's side mount, and a bracket that is bolted (after some drilling) on the stock Kmember. The Madman has two "arms" that bolt directly into the stock mounts.
The point is that if you are using a stock Kmember you could get creative and fab it up fairly easily. If not, you are looking at a little more welding/fabrication.
Good luck. I wish I had a TIG welder :).
edit: And the skills to use it! My MIG welds don't even turn out that well :o.
Ryan
n20ta2
12-30-2005, 11:41 PM
yeah im running a bmr subframe for a 1st gen sbc swap but I spec'ed it for the stock power rack if that makes any difference.
96speed
12-31-2005, 10:36 AM
I have the exact same Kmember. I had the same sbc/bbc Kmember with pinto mounts for a while. The pinto mounts make it easy to basically install any rack you want, but you don't have the option to go back to power steering. I wanted to convert my car back, and I had to get a new Kmember $$$.
Food for thought for anyone considering going with a different Kmember. Not really relevent to anything in this thread :o :D.
Ryan
12SCNDZ
12-31-2005, 12:55 PM
http://www.geocities.com/max_wylde/frontsuspension.JPG
Here's my AJE k-member and AJE manual rack. The rack cost me $600. It is a little pricey, but it's a direct bolt-on, since I ordered the k-member to accept the pinto rack. Very nice kit that comes with tie rod ends, bump steer kit, steering shaft, and steering shaft universal joints. http://www.ajeracing.com/camaro.htm
Frank
96speed
01-01-2006, 11:27 AM
Frank: Now I remember how pretty my setup used to look like!
